Last week I broke out my racing wheels (zipp 404's) on the Ironman WI course on a moderately windy day. I've ridden in the wind before with my training wheels, but that day just got BLOWN away and I felt like a lot of it was due to the 404's. Out of fear of getting stuck with a nasty crosswind on race day, might I be better off looking into some other options with smaller rims? Would Real Design Supersonic 40mm be downsizing quality? Any plugs for the Zipp 202 or other recommendations?
Re: Wheel advice - Zipp 404 vs. others in wind [distancediva]
You must be pretty tiny to feel rough with some 404's since they are only 58 mm. But, Lisa Bentley (also pretty tiny) uses a 303 up front and a 404 rear (well, she did for years anyway) in Kona because she was afraid of the gusts. I would not go down to a 202 though. Perhaps the 303/404 combo would be the right combo of aero benefit vs. comfortable handling for you?
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
Re: Wheel advice - Zipp 404 vs. others in wind [rroof]
Thanks for the advice. No, not tiny at all (thanks to the years of swimming & lifting - about 5'9", 160) but I did just get a bike that is significantly lighter than before. That could contribute some, but new bike + old wheels without rims didn't feel the wind. Why not go to 202's?
I'm about the same height and only four pounds heavier, and also got blown around with the 404's on a couple of recent rides. On the last ride, I was trying out my Zipp disc with a 404 up front. The winds were shifting, so I got pushed from behind, from the left, right and front. The rear was stable, but the front wheel was blowing around a bit. My coach taught me to keep a light touch on the bars, and in very heavy winds to ride the bullhorns, not the aerobars.
GEt a bigger rear. The center of pressure will move rearward and increase your stability. That's why discs are MORE STABLE in crosswinds. The disc counters the steering effect of the wind. If you can't use a disc, get an 808 or H3. My $.02 only
http://blackwellresearch.com/...lity%20Explained.pdf
Of course, this could also mean that a Neverreach will make a bike MORE stable, too, since it puts more sail area in the rear ;-)
_________________
Dick
Take everything I say with a grain of salt. I know nothing.
_________________
Dick
At 160lbs you should have no issues with 404, 606, 808, or 909. I dont.
i'm with record10, i ride a disk rear and a 90mm front, and at 150 i have had exactly one day where i felt the wind at all.
____________________________________________________________
Link to my photography
http://davidsavoiephotography.blogspot.com/
http://davidsavoiesports.blogspot.com/
I weigh 140 lbs. I ride the Zipp 404's over the Golden Gate bridge in really strong, gusty cross-winds regularly. They really aren't unsafe to ride in heavy winds. I don't know how often you practice on the 404's in high winds, but if you're not spending a decent amount of time getting used to how they react in the wind before you race them, I can see where the sensation might be unfamiliar and how you'd wonder whether there's a better alternative. I promise you, however, that the 404's are perfectly rideable in high winds. I rode them at Wildflower in really windy conditions and had no difficulties.
Stephen
Stephen
What day did you ride IMWI?
I was out there on Saturday - 180 pounds on training wheels and I got blown around.
That was the windiest day I've ridden in Madison course, and I've been out there on some windy days.
I echo what sentania said, I got the sh*t kicked out of me last Saturday. I do not think it was the 404s. It was an exceptionally windy day. I am 175 and had Mavic Ksyrium SSLs. I did IMMoo last year with 404s in the rain and wind and had no problems at all.
If there are no dogs in Heaven, then when I die I want to go where they went. - Will Rogers
Emery's Third Coast Triathlon | Tri Wisconsin Triathlon Team | Push Endurance | GLWR
Get a Disc cover for the 404's I'm 5'10 155 and never really had a problem with just the 404s but I did find that the disc cover made things ever more stable and FASTER!
http://www.nunnsontherun.com
StevieK is right on. I originally felt that the Jet60 was too much wheel for me to easily control. With the Renn disc in back it's a whole lot easier as the front end doesn't tend to get "steered" around off the road. I tend to get "pushed" a bit from side to side, which is a lot easier than the front wheel suddenly trying to turn left. This has to do with aerodynamic center, etc.
But my real solution to feeling good with the H3 front/Renn rear is to ride with the Jet60 front and Velocity Spartacus Pro rear (30mm) in a LOT of my training rides. I actually ride this combo almost exclusively and now it's no big deal. FWIW I am also ~160lb and 5'11". One thing to check is the quickness of your steering and the centering effect. When I was using a shorter stem it was a lot harder to control than a longer stem. The "slower" steering of the longer stem/hand position made things a lot easier in heavy winds.
