I’m building up a P3SL with 25mm continental GP4000 tires. Whats the widest rear wheels people have used on this bike that clear the chainstays?
Re: Wheel Width for Cervelo P3SL [khanlon]
P3-SL? You are using an oldie but goodie. The horizontal dropouts should give you some more room to play with if you back it out. However, I find tire varies from brand to brand. So ask for brand if someone says 28mm fit.
From my memory, I would think you are pushing it at 26mm. These frames (cutouts and width of foils) were most likely designed around a 23mm wide tire. This is what I use on my P3-SL.
Re: Wheel Width for Cervelo P3SL [mfrassica]
I have HED Jet + with GP2000II 23mm tires with no issues. The 23s stretch a lot but never rubbed and I’ve put about 2k miles on that setup.
Re: Wheel Width for Cervelo P3SL [Tifosi01]
Biggest problem I ever had was tires that became too tall and rubbed at the fork crown.
