What in the......Flaer Revo Via Chain Performance System
I don't even have words for this. http://flaer.com/
http://flaer.com/revo-via/
http://www.trisports.com/...rication-system.html
Now you can ride faster, ride further, and recover quicker all thanks to the Revo Via Chain Performance System from the innovators at Flaer Cycling! The Revo Via chain lubrication system delivers precise micro-doses of Via Fluid to your bike's drivetrain which increases power up to 12 watts at the wheel. The Revo Via automatic chain lube system not only improves the performance of your bicycle's drivetrain, but it will also keep it significantly cleaner. The specially developed Via Fluid is formulated to deliver maximum power transfer to the wheel, smoother gear shifts and a cleaner transmission. With automatic activation, precise delivery and adjustable frequency, the Flaer Revo Via Chain Performance System will improve overall efficiency while maximizing your effort, from start to finish!
$350.
You have to be kidding right? April Fools? Nope. 12 Watts from chain lube? HAHAH ok sure. All of the friction facts testing we have seen shows 4W max from a fresh waxed chain.
Best chart I have ever seen regarding chain lube. There is no x-axis. What is this? Distance? Time?
If you're worried about the weight, then you should know that the performance advantage outweighs this by more than 17 times, so you'll be faster than you are without it.
17 times compared to what? Aero drag? Weight penalty slowing you down from an automatic chain luber?
Re: What in the......Flaer Revo Via Chain Performance System [BryanD] [ In reply to ]
i believe some pro team is allegedly using this at the moment. can't remember which one. that graph is only satisfying if you're...not too swift.
