I would like to use Ultegra 6800 crank arm from Stages on my Cervelo P3 2014 (FSA BBright). Anyone know what kind of adapter I need? I was looking at Wheels manufacturing adapters but I am little lost as to what size I need. Thank you!
Re: Ultegra 6800 arm adapter for FSA BBright [mnsvk]
This should be it.
http://wheelsmfg.com/bottom-brackets/bbright/bbright-adapters/bbright-adapter-for-shimano-cranks.html
You want to go from BBrite to 24mm Shimano.
As posted above, Wheels manufacturing produce an adaptor from BB30 (or PF30) to allow you to run a shimano crank.
Alternatively, Rotor makes a BB designed specifically for BBright and Shimano cranks. -> From Cervelo themselves "For Shimano & compatible cranks, use Rotor 4624 BBright bottom bracket"
I am unsure that the two things are compatible. A NDS Ultegra 6800 crankarm on a FSA Gossamer BBRight crankset.
At least, that's what I'm understanding you want to do. The previous two posters are addressing issues of bottom bracket compatibility.
