What do you think of these "tubular clincher" tires? I know Tufo gets a bad rap around here, but these tires got an excellent review in British cycle mag Cycling Plus. They look like an interesting option for someone with clincher rims; you can run them at up to 220psi and they're a lot cheaper than most tubulars.
Re: Tufo S3 lite [donm]
Justin in Austin, get it? :)
Cool races:
- Redman
- Desoto American Triple T
Re: Tufo S3 lite [Justin in OK]
Don't you know? If you double the pressure, you double your speed.
Okay, fair enough, but is 120psi really faster than, say 140-160psi? I'm new to all this, so go easy on me!
Probably. Plus your ride should be better. I have a set of TC's on my road bike. I run them at 115, but they are a slightly lower pressure models. They wear well and I ain't had no flats yet. If the RR is higher, so what, I'm training.
_________________
Dick
Take everything I say with a grain of salt. I know nothing.
_________________
Dick
If you ride a real road and not a velodrome, then yes. With a hard tire every little bump means you and your bike must be lifted up to go over the bump (even little tiny bumps). That requires energy which reduces speed. A softer tire absorbs the bumps and doesn't require the energy to lift your weight over the bump.
Cool races:
- Redman
Cool races:
- Redman
I heard it from a guy who overheard a couple of guys say the the Pros in the Tour de France don't inflate anything over 120
Paul "Speedy" Gonsalves
http://www.rollingthundercanada.com
RollingThunderCanada
Canadian distributor for HED Cycling, Blue Competition, Akona Biospeed & Aerus Composites
It depends on the tire. Not all tires behave the same way at the same pressure.
