Currently on stock Felt IA FRD front end, and need some new longer extensions, thought it might be a good time to look at an upgrade...
With regards to the Tririg Scoops Ultimate SL, am I correct in saying that I would no longer be able to use a typical BTB bottle setup? I currently use a very minimal BTB bottle mount - the profile design HC mount.
https://sportfactoryproshop.com/...-hc-mount-with-cage/
Again, I'm -not- using a tririg handlebar, just a stock felt carbon base bar, so assuming no option to use their dragonfly thingy..
For the Scoops arm cups (open or closed), what is the difference between the 'signature' model and the non-signature model? The signature models are less expensive, but they have no description or measurements posted for them to say what is different..
Oh, also....would the length of the scoops arm cups also preclude me from using the profile design HC mount and BTB water bottle? Looks like they may get in the way... :(
Thanks!
Thanks!
