Hey all you awesome Slowtwitch Training Log users!
I've been working long and hard on this, trying to make sure that our integration is easy and seamless. And so finally, here we are: http://training.slowtwitch.com/ now supports limited connection and synchronization from Strava!
Hold the applause. It's very new. Even though I've worked through a pretty good pile of use cases and tested it a bunch, there could still be glitches and mess-ups. The activity type mappings could be wrong, and there could be some additional things that we need to work out as we go along.
Here's how it works so far:
1) you can connect your ST Log user to your Strava one by going to the "Welcome, MyUserName" button and selecting "Strava Integration". No more page not found :-).
2) click "Connect" and follow the prompts to go through the Strava auth process. Our app is named very predictable. Don't worry about the access: we don't post anything to your Strava. Only read.
3) When you're connected you'll see your profile pic, name, and Strava ID on that page. Now click "Synchronize" and it will check your activities in the last week and add missing ones to the ST Log. Voila!
Before you start complaining about the week timeframe, please understand that this is a very soft launch. We'll refine it, update it, add a movable window or an "all" option, and so forth, but we have to be careful initially to not blow our Strava rate limits out of the water.
If you have anything unexpected, please holler back at me here and I'll do my best to fix it timely.
Thanks, and have fun!
-Eric
-Eric
