I just got back from a trip there. I only have an experience from 10+ years ago at the San Diego LSWT to compare to, So take it for what it's worth.
It was much more cycling-centric than LSWT. Aaron is a real cyclist, with real fitting expertise. We went through lots of fit options, carefully considering the implications on power output, comfort, etc -- not just drag. At LSWT, it was more like "well we could try this and you might lower your drag." Kraig W was the only real cyclist there at the time, and I don't think that it was his responsibility to offer fitting-type advice. Maybe that's changed.
At LSWT, we did several non-pedaling runs, which I question the validity of in retrospect. The Faster method was to pedal everything at tempo power or above. It makes sense to test positions &etc as you actually ride them. I have to think that skinsuits, helmets, etc, comparisons are also going to be more valid in the real-world context of swirling legs and a core and head that's bobbing and twisting while you try to push out real power.
The tunnel definitely doesn't look as high-tech as the LSWT or some of the others, e.g. it's not fully enclosed. It's a little weird to be able to see other parts of the shop around the sides. So yeah I suppose it might be less accurate. HOWEVER, consider that the variability in the rider's body position during a run is likely to overshadow even significant imprecision of the test equipment. Why focus on tiny milligram differences when the rider is making movements that amount to mult-grams? Faster's vastly lower cost allows you to do a lot more/longer trials, which should help overcome the rider variability.
My latest book: "Out of the Melting Pot, Into the Fire" is on sale on
Amazon and at other online and
local booksellers
