Installing a new Aluminum seatpost into a carbon frame....what can I substitute (can buy at local Auto Store, etc;) for carbon paste?
Re: Substitute for Carbon Paste [gammy]
Toothpaste.
Re: Substitute for Carbon Paste [Danielg]
wow...I had seen that somewhere before...guess it's for the "friction".
Why can't you go to a bike shop or Amazon? Carbon paste cost me like 3-4 bucks.
Re: Substitute for Carbon Paste [soobrex1]
soobrex1...that's not the issue....I will not be near a bike shop till Saturday and I must ride Tuesday...thanks for your input though.
2nd for toothpaste. The cheaper the toothpaste the better it seems to work. I had an aluminum frame with a round carbon seatpost that used to slip like crazy and a schmear of toothpaste fixed it right up. I wouldn't use anything with peroxide in it, though.
The plural of anecdote is not data. :-)
- Andrew Coggan
- Andrew Coggan
Just wondering as I used to think carbon paste was expensive and hard to find. Anytime I can't get to an LBS I get next day shipping from Amazon. In a jam you can use a simple toothpaste such as Tom's but really it's whatever has the fewest ingredients. Like someone else mentioned, avoid peroxide.
gammy wrote:
soobrex1...that's not the issue....I will not be near a bike shop till Saturday and I must ride Tuesday...thanks for your input though.It's just four or five days of riding. Installing dry is not a problem.
That's assuming your bike doesn't have an aluminum insert in the seattube. In which case you can probably use grease.
http://www.jt10000.com/
Danielg wrote:
Toothpaste.Plus, when you end up removing the seatpost to change/travel, even months later, you'll be greeted with a fresh, minty smell.
However, it took quite a bit of effort to get the carbon seatpost from my Allez (aluminum tube) after using toothpaste and having it sit for a month or so.
