Richard H wrote:
rumpole wrote:
I will add my own anecdata point. After my A race, I started lifting 3x per week on a 5x5 beginner type program. (I'm 45). Since starting, I've increased my ROM in my hips and no longer suffer from back pain at all (knock on wood). My own theory (as applied to me) is that I need to create and maintain a certain level of basic strength on top of which I can pile mileage. Now--when I say basic strength, I'm talking about being able to comfortably squat or deadlift one's body weight for several reps, and I'm about five weeks away from that. I've nonetheless noticed that running has become easier ( Hokas are a godsend), and that high-end power on the bike has improved (although that might be just from being "fresh"). I'm also at the really slow end of the stick, so -anything- might help.
I'm not at my goals yet. My thought is to build strength up to a certain level based on body weight, and then switch to a more aerobic form of resistance training for maintenance once I start preseason training and adding more cycling and running volume. I'll also say that the buzz from squats and deadlifts is not as good as a runner's high, but it's pretty good.
The whole subject of weight training endurance training is a quagmire. Anyone who says he knows is a liar because every athlete is different.
I'm aware of people who have dramatically improved their performance in martial arts and sports which tend to ignore aerobic fitness by doing cardio vascular training. I have seen this, trained people and have seen the results. I know it works that way, what I can't prove is that it works the other way, that is, you take an endurance athlete and make him so weight training and get an improvement in performance.
What I can't prove either way is was it all down to more training. You take an athlete who trains every night, you make him do weight training every morning before work on top of what he normally does and hey presto the lad improves. Would he have improved as much or more if he just did more of what he was doing before? You can't prove one way or the other.
But sometimes you know, but you can't prove. This is the difference between coaching and science.
I completely agree. And sometimes the only way that you know is through trial and error. The way that I look at this is that I sit all day and that means short hip flexors, weak glutes, etc. Squats help fix that, as the weight coming down below parallel forces core engagement and forces those muscles to stretch. Yoga could easily perform the same function in conjunction with SBR training, but for me that requires scheduling a class as opposed to sneaking in when I can.
I think you do build up the same fitness through specificity--someone who can run a 3:30 IM marathon has plenty of strength relative to their weight. And I think that there is some minimum of strength and flexibility necessary to be able to pull that off successfully. What I'm wondering is if I can build a stronger foundation and then layer the speed and endurance on top of it for short course events. In any event, it's created the side benefit of making day to day life a lot easier, and it's fun. (That's why most of us do this, right?).
And finally, I see a lot of things saying that "weight training produces no gains in trained cyclists vs. a cycling-specific stimulus." It would be very helpful as a layperson to know what the definition of "untrained" is. Is there a uniform benchmark for "untrained?" Is it someone coming off the couch? Is it someone under 3 w/kg? 3.2?
owner: world's tightest psoas (TM)
