First to the OP, as everyone else has said, ignore the estimated power in Strava. I'm sure it can be occasionally close under the right conditions, but it is more often than not wildly inaccurate.
feldon wrote:
Actually, using a Quarq Power Meter with a 310xt Head Unit, I get different power numbers all the time in Strava. Strava will always have my power numbers lower than what the Garmin unit reads or what Garmin Connect says. My advice to the OP is disregard any power data you see in Strava.
I'd also take the power metrics reported by GC with a healthy degree of skepticism. Obviously, the AP can vary a lot depending on whether you've included 0s or not, but for newer devices with the power metrics, the NP (and corresponding IF/TSS) have always been way higher for me than those that are calculated by any other source.
My metrics as calculated by WKO+ and GoldenCheetah always correspond closely, however the same ride data as reported on GC will show tangibly higher power and therefore I definitely don't recommend using it as a the sole source of your data.
