I dropped my stem down about 1 1/2 inches and would like to cut off the excess. Any tricks or precautions in performing this surgery? I figured I would put an old spacer on (the height of my stem) to use as a guide, and then just hack it off with a good saw. Any other thoughts?
Thanks
If it uses one, make sure your star fangled nut is down far enough first... :)
Use a miter box for a nice, flat, flush cut. Use black electrical tape over the cut to minimize splintering and a fine hacksaw blade - Easy!
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
is it a carbon or aluminum steerer? either way, this oughta get you where you need to go:
http://www.slowtwitch.com/mainheadings/techctr/maintenance/steerer.html
http://www.slowtwitch.com/mainheadings/techctr/maintenance/mitre1.html
Dan Empfield
aka Slowman
