Barchettaman wrote:
The saddle rails are relatively short and forward, so if you need a really steep position with the saddle slammed forward you might be out of luck.
Agree with the comment re hydration, the integrated bosses are a nice touch.
With an M-Wave adaptor you can use two cages, if needed (no bottle bosses on my BP Stealth!)
The bit about the rails is what I was going to say, but bear in mind Dan's article on saddle position if you are replacing something that had a nose with this. You further forward on this saddle.
Also, I have this saddle on my P3C in the foremost of the two mounting holes, and by fitting the saddle forward this means that I cannot use the integrated bottle bosses. The rear portion of the seat post fouls the bottle mount. I imagine this could be a problem on any seat post with a similar mounting system. You can just about see what I mean on the picture below.
For me, this saddle fits my particular arse dimensions better than any other. But you have your own arse, so YMMV. I went through Fizik Arione, Selle Italia SLR Tri, 2x ISM Adamo and Cobb V-Flow Max before landing on this. I'm sticking with the Sitero.
