Re: Slowman says Jens' seat is too high... [Slowman] [ In reply to ]
It seems that most would agree that the new position is more comfortable. The current set up on my tri bike is similar, and I feel very comfortable on the aero bars for extended periods of time (2-3 hour rides)
For shorter rides such as a sprint triathlon (less than 1/2 hour) do you really need to optimize comfort, or should you go with a position that is somewhat more aero?
Re: Slowman says Jens' seat is too high... [Tom A.] [ In reply to ]
In Reply To:
Even so, I don't recall exactly, but the nose of that saddle is pretty short and Jens is pretty far forward. I can't remember if it's UCI legal or not, but I'm pretty sure it's close (within ~1 cm or so). Jens?
The saddle tip is close to legal -- about 3cm back. I can pretty easily push it to 5cm without changing my position, just by nose-riding a little more.
--jens
to be clear on the issue of saddle height and its relevance to hip angle, the saddle height is tackled first, before anything else (according to the protocol to which i ascribe), rendering the question moot for the purpose of arriving at the appropriate bike fit.
Dan Empfield
aka Slowman
In Reply To:
True...and I fully understand. It's just that when we measured "your angle" for the old and new positions yesterday, we were all somewhat surprised that the difference was only 3 degrees. I'm just saying that the lower seat of the old position would actually make the "thigh-torso" tighter than what your proxy angle would suggest, i.e. the difference was greater.
I'm just bringing this up in the context of the other thread that started this whole thing ;-)
Can someone explain to me why his position needed to be changed in the first place. What was the motivation to being changed. I also don't really understand the relationship of the "triathlon" FIST fit with a guy who just does time trials. Why couldn't he have just raised the saddle and left everything else the same?
I thought one of the benefits of a steep angle was the supposed value of saving one's "running legs" as the pattern of muscle recruitment is different. Correct me if I am wrong but I thought Jens didn't do triathlons, so shouldn't a position that optimizes power to drag ratio be the correct position regardless of how one achieves it. Now, I know that Jens has been in a wind tunnel so has his drag numbers down and has a power meter so I am sure he knows his Power/drag ratio for his old position. What is it now? The After position certainly looks at least aesthetically to be less aerodynamic. So how much power did he gain?
Re: Slowman says Jens' seat is too high... [DoubleTrouble] [ In reply to ]
It came from the comfort/aero thread a few days back. Search and you should find it. Realistically, what Jens needs, is to find a way around the UCI rules that will be enforced next year. I believe this was Dan trying to help him.
Second, I think part of Dan's argumen is that steep is no longer a tri only thing, i.e. Zabriskie.
In Reply To:
See the start of all this, the "aero vs. power" thread from last week:
http://forum.slowtwitch.com/..._reply;so=ASC;mh=25;
Also, one thing I gathered out of watching the fitting session yesterday is that there was absolutely no thought into "saving muscles" for running or anything like that (obviously not meaningful for a TTer). Once the proper seat height was set, the adjustments for the fore-aft position of the seat and the bars was an iterative process that depended on a lot of feedback from Jens about what felt better from a power production standpoint while pedaling with a moderate load being applied by Dan's CT unit (btw, the CT wasn't used in any fashion besides applying a steady load, i.e. erg mode).
It got to the point of making minor adjustments with Dan asking Jens "Does this feel better, worse, or the same?". I even asked Dan at one point if he'd had training as an optomotrist since it sounded like I was watching a lens prescription process ;-)
The whole point was to try to gain back some of the power Jens lost (as compared to his road position) in his aerodynamically optimum position. If he gains 20W of output but only gains 10W of drag, that's a net win for him. Now it's up to Jens to evaluate and/or tweak the position to get his best power/drag ratio.
My only comment is that Jens now needs to change his handle to Jens-compatto. The change of name is not something that just anyone can get from Slowman. This is like going to Buckingham Palace and getting Knighted...or as close as you can get on ST. Even Bjorn, after training in Xantusia and winning Wildflower is yet to get this from Slowman.
Re: Slowman says Jens' seat is too high... [devashish paul] [ In reply to ]
I don't think going steep has anything to do with saving the running legs really. If you do it properly the whole point is that your body is in the same position just rotated so that you have less frontal area. I know some studies have shown people to run faster "Steep" but I wonder if this is just because they had less drag and therefore spent less time at their power output?
I just had the bike of my life this morning in a triathlon and it was the day after I figured out how to make the aero position feel (to my legs) just like a normal road bike position (i went steeper which opened up my hip angle)....and running sure hasn't ever felt easier in any way no matter what position I was in =)
Re: Slowman says Jens' seat is too high... [jackmott] [ In reply to ]
I believe the study you are referring to was conducted indoors on stationary bikes, so drag wasn't a factor.
Re: Slowman says Jens' seat is too high... [JohnA] [ In reply to ]
In Reply To:
Was the study comparing steepness of seatposts or openess of hip angle?
Re: Slowman says Jens' seat is too high... [Dreadnought] [ In reply to ]
Slowman discusses the Garside study here...
http://www.slowtwitch.com/...chctr/seatangle.html
 Thanks for the link. I thought this item was interesting:
"This particular study simply utilized a seat shifter, a nifty device once in relatively common usage by triathletes in the early '90s. It replaced the bicycle’s seat post, and with a lever on the handlebars you could change your seat angle on the fly. I’ve tracked down the study’s author and emailed him, asking him to verify that no changes were made to the handlebar set-ups as the seat angles were altered during his study. I’ve yet to receive a reply. I don’t, however, see any notation that any change in the bikes was effected other than a change in the seat angle provided by the seat shifter."
Are these seat shifters still available? Might be something worth using for a training ride along with a powermeter to find your optimal angle.
From a 1990 article:
"Steep angled seat tubed bikes will be non-existent, as will LeMondesque shallow angled seat tubed bikes. In fact, seat tube angle will become largely unimportant as riders adopt systems for altering their seat positions and effective seat angles while riding. Virtually everyone will utilize a system such as the brand new Seat Shifter (an American product from San Carlos, California), which allows the rider to choose four different positions of the saddle in relation to the bottom bracket via a small handlebar mounted lever. Riders can set the Seat Shifter to provide their standard/ hill-climbing/ behind the bottom bracket position as the rearward most setting on the seat shifter, thus allowing three forward positions with a total of 4" of travel. When hill climbing, riders can move the saddle back, sit up, and climb in their most effective and efficient position. On a long climb, they can alternate between this position and the next forward position to change muscle group usage and reduce fatigue. On downhills and flats, riders can slide all the way forward and stretch out onto their aero handlebars, gaining a two to three MPH speed increase by dramatically increasing their biomechanical positioning, efficiency, and comfort. Once again, riders can alternate between this forwardmost position and its next closest position to reduce fatigue and enhance recovery. Not only will this type of system make cycling faster, more efficient, and more comfortable, but it will also eliminate almost all cases of lower back fatigue and Shermer/Solon neck."
Another comment from the link:
"The authors only guess at the causes for the enhanced ability to perform with the steeper seat angle, and posit about the,
"greater contribution of the hamstrings and gluteus muscles (Heil et al., 1995). Although muscle recruitment cannot be determined from the present results, alterations in muscle recruitment or activation patterns can have the effect of distributing muscular work over a greater muscle mass (increased contribution of the hamstring and gluteus muscles) that would theoretically reduced the work rate per individual muscle fiber (Coyle et al., 1988).""
That seems counterintuitive. If you are using the glutes and hams more, wouldn't you expect them to be more fatigued at the end of the ride? How would that help the performance on the run?
Re: Slowman says Jens' seat is too LOW... [Tom A.] [ In reply to ]
The new position sure looks more comfy and "normal". But any discussion is purely academic. The real proof in the pudding is when Jens does a few TT's this way and compares his times to those in his old position. Only then will we know what works best for him.
"Are these seat shifters still available"
M2Racer made a similiar device a few years ago. I experimented with one on my Giant TCR about five years ago. I thought the device had merit, but found it difficult to adjust on the fly and it felt a bit "wobbly", even at my 150 lbs.
Re: Slowman says Jens' seat is too high... [cerveloguy] [ In reply to ]
In Reply To:
Thanks. I found their website.
When you say "wobbly" do you mean only when shifting or during the entire ride?
When I say "wobbly" that means that there seemed to be a lot of flex in the system at all times. I noticed it throughout the ride. The shifting part was difficult because you had to move a lever and then shift your butt forward or backward. Sometimes the saddle just didn't want to co-operate as it would seem to bind a bit on the rails.
As mentioned, I think the unit has some merit, but needs a better design. In the end I just got two seat posts - setback for road and neutral for tri. Ran the TCR much like a Soloist this way.
the problem is that the cda at o yaw meaby faster but in yaw slower
and give away lot power that for better cda that mostly worse idea
at least even pro cyclist do not want to do that ,
you really have to isolate the rider from the bike at several yaw angle
and also measure the power closely to have a good measurement
there is a lot to it
more weight on the front can also mean greater crr of the tyre
as the latest test we did we saw that crr is not linear as you would expect
but making a S curve
well al this depands on tyre construction and road and speed of course
http://www.ada.prorider.org
skype ceesbeers191053
