Do you get the same effect from doing SFRs (aka Big Gear reps) on the Computrainer vs outside on a hill if you hold the same watts and % grade for each? If not, what is the difference?
Edit:
Assuming you could cailibrate your CT and PT to deliver the same readings, which you probably cant, but for sake of argument, lets assume you can ......
Edit:
