Bio_McGeek wrote:
Interesting. Hard to imagine why it would be awkward. Couldn't be smoother in my lab or in several other labs around the world.
How did you attach the weight? Maybe a pic would help.
Cheers,
Jim
I took some pics, but I was unable to attach them to my post. I'll try again. I can tell you what I did. I brought weightlifting bar to the machine shop. They cut it to about 5" in length and the threaded one end of it so that it would fit into the crank like a pedal. Then I put 2 x 5 lb weights on it plus the lockrings. My estimate is that the total weight was somewhere between 10 and 12 lbs. I can email the pics to you if you want..
I should point out that I've done a fairly large amount of non-counterweighted single-leg cycling. My guess is that I've become accustomed to using my hip flexors so much that the counterweight disrupts my usual rhythm.
