Couple of shoes that spring to mind
Brooks Glycerin honestly this shoe is so much better than the Brooks ghost for only $20 more. It's a $35-50 upgrade in feel, fit and ride imo
Asics Cumulus or nimbus, although I think you'll probably like the cumulus better based on what you typed, I'd be willing to bet a Pepsi on that. On a side note the Nimbus is what 80% of Bondi loyalists I fit into shoes are moving to. 80%, never seen a conversion rate that high from the Bondi to any other shoe....ever. I don't want to say Asics is back just yet, but they have a really solid lineup across the board
maybe the NM 1080 or even the new 840 and 880. The new 840 gets away from thinking Dad shoe.
Saucony triumph. You may also like the new Ride. Saucony dumped a lot of $ into this shoe (and the Guide) and it's a really good update. I also like the Kinvara Pro (to me this and the Hoka Mach X are almost interchangeable - see below). The updates are so much better it's not worth it to buy the older version which is on sale.
Hoka, honestly, if you came in I'd have put you in a different Hoka than the cavu. Now though it's harder to recommend a Hoka. So many other brands have caught up and surpassed Hoka for cushioning and feel. But if I was, probably the Clifton, although you may like the new Mach X
You might like the Mizuno Wave Sky
That should give you a good jumping off point. I can't remember if you said you needed wide's, someone mentioned wides, but most of these are available in wide width.
All you stability shoe users I really like the new Guide. I mean REALLY like especially if you're a Hoka user. And the Saucony Tempus. Those along with the Brooks Glycerin GTS are the 3 best stability shoes out there for daily miles imo
Hope that helps
Brian Stover USAT LII
Accelerate3 Coaching Insta
