ilikepizza wrote:
-I wear them with running shorts over the top (i wear more undergarment than tri-short ones...or lack confidence), and cut out the brief liners from my running shorts.
-They aren't much hotter, and there are some that have are more mesh-like in certain areas to aid in airflow
-I like Nike pro combat, but am sure they are almost identical to under armour and many other brands
-Yes. I do not wear anything underneath, and they keep things in place. For longer runs I swipe bodyglide first.
As someone else noted, you may try shorts with built-in compression liner, I have a few pair of Nike shorts like this that work pretty well also but a little less "compression"
I throw running short over the top as well. Out in the country where I live there are enough people yelling, "Fag" at me when I am just running. Doing it with just compression shorts seems like poking the crazy with a stick.
I'm beginning to think that we are much more fucked than I thought.
