Anyone know the best way to remove the magnet/putty? It's been on there solid for 3.5 years and I have no clue what approach I should be taking. I hear it's a PITA, but short of a jack hammer, what tool(s) should I be using?
Re: Removing quarq magnet affixed by putty [Jason N]
IME: A slight tap from the side will break it free.
drop your chain. works every time for me....
Re: Removing quarq magnet affixed by putty [Shinny]
Shinny wrote:
drop your chain. works every time for me....This
Two options (outside of dropping the chain...), use a flathead screw driver and place it on the side of the magnet (staying away from the frame), then give it a tap with a rubber mallet and it will fall off. Second option is just to leave it on... you can't see it anyway since the crank is in the way.
"Suddenly the thought struck me. My floor is someone elses ceiling"-Nils Ferlin
audiojan wrote:
Two options (outside of dropping the chain...), use a flathead screw driver and place it on the side of the magnet (staying away from the frame), then give it a tap with a rubber mallet and it will fall off. Second option is just to leave it on... you can't see it anyway since the crank is in the way.Screwdriver with a tap from a rubber mallet worked very easily. Didn't want to leave it there as it attracts a lot of road grit that I constantly need to clean off.
