I'm considering putting some clip-on aerobars on my road bike and was curious on how much time these might actually save me in an IM distance race.
I loaded my stats into best bike split and compared times for a relatively flat IM (Kalmar) bike-split with three 'racing positions':
With 'racing position' defined as: The position that you spend the majority of a race in
The results surprised me:
I'm wondering how common, and what are the conditions that riding on the drops seems to be more aero than in two reasonable aerobar positions. BBS even mentions that drag may be lower on the drops than on TT bike, however I've never heard this brought up in the general drops vs aero discussions and it seems such common knowledge that slapping on aero bars is an easy aero win, all else equal. I'm wondering if this is a common tradeoff.
I.e. Is it common to accept less aero positioning on aerobars in exchange for not having to waste the muscular energy trying to stay in the drops for the majority of 112mi (is staying in the drops for 112mi even a thing)?
- Drops
This setting is reserved mostly for those racing on road bikes in short time trials where an athlete will stay in the drops. It is possible for the drag to be better in the drops than on a triathlon or time trial bike depending on the athlete. - Aerobars (Recreational Triathlete)
This setting is for those who have very little flexibility and use the aerobar more for long distance support. On a Tri Bike if your bars are at or a bit above your seat this may be a good setting for you. Consequently you could also measure your Torso Angle and if it falls in a 45+ degrees range this would be a setting to start with. - Aerobars (Midpack Triathlete)
If you are not very flexible and have a fairly upright position this is a good starting setting. If you are using clip on bars you may want to start with this setting as well.
