You can configure it to allow on some sites and block on others...take a look at that link. (You can also disable that bar at the top too and put a small link on your status bar at the bottom instead).
- Tools --> Popup Blocker --> Popup Blocker settings --> Turn On
- Make sure forum.slowtwitch.com isn't in the allow list.
- Uncheck show information bar when popup is blocked. (a tiny icon will show up at the bottom status bar when blocked rather than that large information bar at the top) If you right click that tiny icon you get the same menu as the information bar to temporarily allow, add to allow list etc.
If you do this you shouldn't even notice it.
If you enable your popup blocker and you can't click links then you have your popup blocker set to "high". If you set it to "medium" then links that YOU click resulting in a popup window (e.g., ST links) will work.
- Open Internet Explorer.
- On the Tools menu, point to Pop-up Blocker, and then click Pop-up Blocker Settings.
- Select the Medium setting in the box near the bottom of the dialog box.
If you want to see pop-ups that are blocked when you have this setting turned on
High, hold down the CTRL key while clicking the link.
Don't hold back
