monty wrote:
Thanks Andrew, so my race pace mile could be about 150 calories per mile on the high end, even though my jogging pace is 136 per mile or so. Or it could be the same..Still doesn't seem right if I run a 5 minute mile and a 9 minute one, they burn basically the same calories. I would expect some penalty for running the engine a lot hotter..
SO why is swimming so much more +/- than cycling and running??
Re. Penalty for running the engine a lot hotter.
A few factors are at play here.
Oxidation of CHO requires less oxygen than that of FAT. So, there's that.
More importantly, however, is the change in running mechanics across speeds. If your mechanics stay solid, you can have a fairly flat RE across speeds.
Some exhibit additional caloric burn / inefficiency at low running speeds (e.g. increased vertical oscillation). They can improve as speeds increase. Or Vice-versa.
RowToTri-
Re. 5k pace. Remember that this is analogous to determining FTP through a 20 minute test. Those with an increase anaerobic vs. aerobic ability will outperform at shorter distances and will have a comparatively low FTP.
Because of that and the differences in Treadmill vs. Overground running per individual, it is my opinion that laboratory tests ought to always be validated with outdoor performance testing (for both cycling and running).
I talk a lot - Give it a listen:
http://www.fasttalklabs.com/category/fast-talk I also give Training Advice via
http://www.ForeverEndurance.com The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
