warwicke36 wrote:
So at what percent of your FTP (you don't know you have yet) are you supposed to do that effort? Seriously though? All out is pretty ambiguous for a test protocol.
I target 110% of what I think I can do in the 20 min FTP test
I agree that effort is ambiguous but that's why it's called testing. If you are consistent with your testing procedure then your results will likely reflect your changes in FTP.
If someone used just the 20 min test, it will most likely give a fair approximation of their FTP but slightly higher. Then there is that 95% thing, I've found that I'm more like 92% of that 20 minutes so even more variation to that test.
Is that amount significant? It depends on what you use it for. If that person used a slightly inflated FTP to calculate effort for a race and used recommended efforts from someone that did the test differently, they may/may not have an issue with that effort. They should be working with that effort while training to find out if that is a good pacing strategy anyway so if it's off a little it probably won't make a difference. Some people like bigger numbers, if that's what keeps them riding then they need to realize that references to FTP are slightly different from what they did.
If they are using it to just set training zones it probably won't make much difference. It would be a nicer number to brag about though.
If you really want to nail down a FTP you need a longer effort, personally I like the 2X20(4) test or I take the power from a flat Olympic distance race that I had a strong bike and run in and divide it by .90 That is a little vague but it works for me, I also don't have an FTP that most people would brag about.
My $.02
jaretj
