STP wrote:
As mentioned, you can get a very good taste for training with power using virtual power on TrainerRoad starting tonight with a minimal investment. All you need is a trainer, a laptop or computer, an Ant+ speed sensor (your Garmin will work) and an Ant+ dongle for your computer. You probably already have all that but for the dongle and those are only $20-$50 depending on how hard you shop.
After several years of using virtual power on TrainerRoad, I ended up with the low end Quarq and got it with a discount coupon for less than $700. It has been flawless. If you are looking at crank based power meters, one thing that is confusing is you have to know something about bottom brackets to make sure you get one that fits your bike, or you get the appropriate new bottom bracket to make it fit. They also take a bit of assembly since you need to install your chain rings. You definitely can do all that yourself but this is something that if you are not kind of a wrench, it may be worth working with a bike shop on.
One of the advantages to a power tap wheel is those are 100% DIY for even the most unwrenchy cyclist. But, as you mention, you are then limited to one wheel (but I think you can rent race wheels with Power Tap hubs so you might want to look into that if you want a Power Tap).
The crank arm and pedal PM's are easy to install and swap between bikes. The pedals in particular are pretty much compatible with any bike out there. A beef against the crank arm ones are only measure on one side. That freaks some people out but my friends who have them seem happy. The pedals are nice but they are more expensive then the low end crank based models.
I forgot you don't get a dongle with all Garmin devices. I had one already for uploading activities from my 910XT but now I think about it there was none with the 920XT since it's WiFi enabled like most of the current devices. So yeah, you may need to buy an ANT+ dongle.
I was planning to get some cleat based power measurement via Brimm Brothers Zone DPM but then after several years of development and a couple of postponements on launch they folded last year without going to full production due to accuracy problems. :(
I ride my road bike and tri bike about equally and really don't want to be swapping components back and forth. Pedals or a wheel would be pretty easy but I use Speedplays and don't want to change and the wheel option limits you to a single wheel. The cleats system would have been perfect as it leaves the bike out of the equation completely. Oh well! I might settle for a powertap hub at some point, but not for now. To be honest I'm okay with power on the trainer only. I do like my data but if I had power on the bike for outdoor rides I might be inclined to pay too much attention to it and enjoy my easier rides less. Sometimes it's nice not to have too much data and be able to blame the terrain or wind for a slow pace!
