esox.flucius wrote:
Advice from the experts please;
I have found a great spot to do laps which is;
a) near to home (very repeatable)
b) a 'good' length (0.8 mile)
c) very quiet outside of normal working hours
d) has variability in gradients
BUT there is a roundabout at the bottom of a slope (I'm blind to traffic approaching the r/a due to the layout) meaning that braking is a necessity (I don't fancy chancing it).
SO... can I use the laps BUT get rid of the braked data? Would it be easier to not have that section of data included in the first instance; my plan is to stop the Garmin at a particular point each lap BEFORE braking and then restart at a point at a similar height (after ascending from the r/a). Would this still give usable results and would it be better to set the Garmin to start and finish at specific points (so I don't have to fiddle with the Garmin/get out of the TT position etc)?
As AndyF and Lanierb have said, it's possible to snip out the part where you brake -- but it's kind of a hassle. If the next best venue is far away, I'd use this one and snip it. If the next best venue is close, I might use that one.
I do what Lanier and Andy do: I identify a landmark (can be a chalk mark you "X" onto the pavement) and hit the brake hard there or hit the interval button (depends on how fast I'm going) then turn around and when I come up to the "X" from the other side I hit the interval button again.
The hassle part is that when I snip out parts of ride files, I can't really use Aerolab since there's an "offset" in the elevation at the point when I hit the brakes. I have a bunch of little code snippets that let me analyze the data so I use those, but not everyone can do that.
