ginofairplay wrote:
Hi,
I'd like to hear from any cyclist who have either ridden or owns this model bike. I'm curious to it's comfort? Is both the seat post and front shock easy to get used to and does it really add to the bike?
Thanks
I've had one since April of 2017. It has 2500 miles and 4 crits on it. The only mod I've made is I'm not using the road kit that is supposed to come with it because mine showed up missing, so I took the credit and bought a road bandit instead. I also have a Praxis crank and a Power Tap C1 on it instead of the shimano crank. Otherwise it is still stock, although the rear tire was replaced 2 weeks after I bought it due to a broken glass bottle I didn't see in time. Tire had no chance. I even have the same chain on the bike.
I'm 6 ft, 175 lbs., and ride a 54. That is one size smaller than I measure, but I do that because I crit race and, at least in my head, a smaller frame handles quicker. The 54 could be fitted to me perfectly with a new stem, so no loss.
I have the heavy spring installed (40 lbs?) and I never notice it move except at the start of the race when I bounce it to show someone how it works. The seat flex is another story. I notice the seat flex when descending really fast (over 30 mph) on rough roads. Unlike the front end that I can't really feel move, my ass tells me every time the seat moves. A bit unnerving at first but now I just go with the flow.
As far as handling goes, it handles as well as my old (2007) Allez. It is no heavier, probably lighter, and it can be tossed into and out of corners with no problem. Climbing out of the saddle is the same story. I don't notice the front end moving when I am pulling on the handle bars. Same story in an out of the seat sprint - no movement as I toss the bike back and forth. So is it worth the hype? Not sure. There are too many differences between it and what I came off of to be able to isolate what is making it better. I know it is a much more compliant ride than the Allez, but it is also running 28c tires on a 24mm rim at 90 psi, instead of 23c tires on a 19mm rim at 115 psi.
The bike seems to be a well thought out total system. Oh, and it stops better than any bike I've had under me.
"...the street finds its own uses for things"
