michael_runs wrote:
ether wrote:
I know there are conflicting opinions as to whether it matters whether you are in the extensions or on the base bar while on the bike trainer.
Would it matter during FTP testing and hard intervals? Would it be better to test lower for FTP/miss an interval or be on the base bar and hit the numbers?
Last season I had an FTP test where I sat up for the second 10 minutes of the test interval b/c
I just couldn't hang on in aero any longer at that power output. That was my highest 20 minute output the whole season but the calculated FTP from that interval was in no way realistic. Train like you intend to race. I find that my FTP tests where I test fully in aero result in realistic approximations of my FTP.
I know I'm not a fitter or coach or anything similar, but surely the position that you would want on a tribike is one where you can be in the aero position for extended periods of time whilst working at a high level of output?
and off the back of that, should we have a different ftp value for different positions of bikes.
eg, I have a higher measurable 20 min ftp on the drops on my roadie than on the bars of my tri bike, but when using the tri bike, I use the tri bike ftp as my measure.... as the roadie one would not be relevant.
so back to your situation above, a FTP of say 270 watts sitting upright, but that may be 110% of your aero bar FTP... which do you select as the measure upon which to base your training?
