Didn't see anything in the search so I figured I'd post this:
http://www.nikolainnovation.com/
Features/Claims:
-25mm of lateral float
-Look Keo cleat compatibility, SPD-SL coming soon
-7% increase in peak power
-135 seconds saved in a 40k tt
So if I combine this with Q-rings will I my power increase by 13%?
The premise of the pedal is that you push down and out. I actually like that concept but I'd be curious to know how it works/feels in practice. I'd also be curious to know how this pedal fares from a friction standpoint.
What say you 'twitchers?
Edit: upon further review, "float" isn't quite the right term. It appears that the pedal has a pin that interfaces with a cam profile on the spindle. Thus the pedal effectively forces your q factor to a minimum at TDC and maximum at BDC but apparently you can adjust these "timings" as well.
Features/Claims:
GreenPlease: Sep 14, 14 16:57
