What could be the cause of it losing air? The tires are brand new(never used) and brand new Silca valves. I can't hear it hissing air anywhere but its loses air within a couple hours.
New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure?
Re: New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure? [Mrdavidalex]
How much air loss
Re: New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure? [Kenney]
Last night I filled it up to 115 PSI and this AM it felt like it was 50% filled. I pumped this AM to 120psi and within a hour it lost some air. I didn't measure it.
Latex tubes.
The other tires I installed is holding air though.
Then I do not know
Mrdavidalex wrote:
The other tires I installed is holding air though.same exact model tire?
Anyway sometimes tubies have tiny holes or bad valves.
it happens
Re: New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure? [jackmott]
Same exact tire...brand new...never used. Should I request a new tire?
Mrdavidalex wrote:
Same exact tire...brand new...never used. Should I request a new tire?If you glued it on, you are schitt out of luck.
If you haven't yet glued it on, I would check and ensure all the extenders are installed properly adn that the valve core is functioning properly. take some soapy water and coat the valve and extenders in it. If you are losing air that fast, it should show signs of it.
Chicago Cubs - 2016 WORLD SERIES Champions!!!!
"If ever the time should come, when vain and aspiring men shall possess the highest seats in government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Re: New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure? [Power13]
Yup already glued...argh!
My suggestion is to get some orange seal, squirt an ounce or two in the valve, pump it up and spin it. Sounds like you have a very small slow leak. This should/will seal it and you'll be good to go.
Heath Dotson
HD Coaching:Website |Twitter: 140 Characters or Less|Facebook:Follow us on Facebook
Heath Dotson
Re: New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure? [Ex-cyclist]
Its a new tire and it should work without sealant. I guess I will try to get refund and try a new one.
If you already glued it, then you are pretty much out of luck unless the shop glued it for you and you haven't ridden it. Then you might get a new one. Good luck though.
Heath Dotson
Heath Dotson
I have a an older Victoria Corsa CVO CX with latex tube I use for TTs. It loses about 3 PSI per hour.
Re: New Tubular tires and Silca Valve extender...pump them up and within a hour losing pressure? [tburke]
I think I might have figure it out. The removeable valve core that I attached to the valve extender was leaking air where it threads on. I dipped into water and there was bubbles coming out. I took some plummers tape around the threaded part to seal it better. The bad thing is I took the tire off the wheel and not I have to glue it back on...arggh!
