I want to cut my steer tube on my Cervelo P3 and I see that they used an aluminum insert with a star nut. Will this cause a problem when I cut off the excess on top of my steer tube? What do I do if that sleeve has been epoxy in place
Re: NP3 steer tube question [Fishbum]
How much do you want to cut off, the insert is reasonably long, depending how well it was epoxied in that there may not be much epoxy at the far end, in which case either remove it and glue new insert of fit carbon expander
Re: NP3 steer tube question [neilridley]
neilridley wrote:
How much do you want to cut off, the insert is reasonably long, depending how well it was epoxied in that there may not be much epoxy at the far end, in which case either remove it and glue new insert of fit carbon expanderAbout two centimeters is what I want to cut off
Is the starnut below where you want to cut it?
Re: NP3 steer tube question [jimatbeyond]
jimatbeyond wrote:
Is the starnut below where you want to cut it?No
Cut a little off the steerer tube.
Use a starnut installation tube to push it further down.
Cut the steerer tube to the length that you want.
jimatbeyond wrote:
Cut a little off the steerer tube. Use a starnut installation tube to push it further down.
This,
Having said that I have had to of these fail do to poor install, so I just moved on to the threaded inserts.
Much better for re-sale and adjustability.
Cheers,
Re: NP3 steer tube question [mauricemaher]
Ty
mauricemaher wrote:
Having said that I have had to of these fail do to poor install, so I just moved on to the threaded inserts. Much better for re-sale and adjustability.
Cheers,
Can you share more about how the insert(s) have failed? What was deficient about the install(s)? I got a few cervelos in the house, and I am building up one so it would be interesting to get your feedback and some more details. Thanks.
Re: NP3 steer tube question [DarkSpeedWorks]
DarkSpeedWorks wrote:
Cheers,
I think the typical issue is that once city shorter, starnut tapped deeper and too cap tightened the epoxy can break loose and separate the insert. The ones I've seen these happen with were cut down more than 2cm so perhaps the glue on the bottom half of sleeve was not consistent. Or it could just be how clean the installation was performed. I just use the fix Maurice mentions with a threaded expansion insert in place of sleeve and starnut.
Re: NP3 steer tube question [SummitAK]
Cheers,
If you have a failure and you use the other method do you then in turn remove the metal sleeve
Yes,
the reason for failure of bond could be over torquing on my part or lack of cleaning/ good bond on the shops part....hard to say.
But yes if you install the threaded insert then pull out the epoxy one.
Cheers,
Maurice
Cheers,
Maurice
Adding to what Maurice mentioned above, when the sleeve fails it typically comes out completely...
Cheers,
I gave up a long time ago on the insert and use this on all of my Cervelos: Origin8 Compression Plug
https://www.amazon.com/...01?ie=UTF8&psc=1
