RunFatboyRun wrote:
crolson24 wrote:
So did that that fat old guy, no disrespect intended to fat old people, but it lessens the accomplishment.
I see this line of "logic" all the time. Can you please explain in a reasonable manner how another person doing something "lessens" what you do?
The initial statement that I made clearly identifies how it "lessens" the accomplishment, but I will give another circumstance that clearly explains this as well. In the case of the GRE for entrance to many masters and doctoral programs throughout the country uses this as a way to rank the testers. For instance, if you take the test and score well on the quantitative and verbal sections of the test, you could still be ranked in a low percentile of testers based on how they did. In the same case, if a ton of stupid people take the test and you do OK, you could be in the 99th percentile. It doesn't mean you are a super genius, it just means that you did better than a bunch of dumb people.
If this doesn't make sense, I apologize, but I feel that it is a good example. If not, I could attempt to use a couple of unrealistic examples that could exaggerate this point even further.
Thanks for the feedback, and no offense to "dumb" people as well. ;)
________________________________________________________________________
"That doesn't make any sense at all, you can be second, third, fourth... hell you can even be fifth." - Reese Bobby, Taladega nights
