This week in an interview with L'Equipe, Greg Lemond said:
I've never heard of a direct correlation between vo2 max and power at or around threshold. Is Lemond way off base here, or is there an actual documented correlation?
I mean, I know of quite a few guys who push 400+ watts (and with Strava, it's pretty easy to see what some top pros are doing to more or less verify that), but a vo2 max of 93 seems like rare territory indeed.
Quote:
“When I raced, I had a VO2 max of 93, and I never developed more than 400 watts. Armstrong’s VO2 max, which Ed Coyle mistakenly revealed, was no more than 78. So, considering his weight - 73 kg, he could never produce 500 watts to ride up the Madonna as he said, or 475 watts on the climb of L'Alpe-d'Huez. With his VO2 max, he couldn’t exceed 375 watts. To increase his performance by 30%, he had to dope. But did he achieve his performance only with doping? What doping did he use that others didn’t? All I know is that there are 50-70 watts missing, which we don’t know the origin of. There is something that I still do not understand.”I've never heard of a direct correlation between vo2 max and power at or around threshold. Is Lemond way off base here, or is there an actual documented correlation?
