Hello grumpier.mike and All,
I will have an LG P-09 helmet ordered that should be delivered in a couple of days to experiment on.
I noted in the pictures that the visor is supported in the center with a ventilation gap all around the lens.
If the vent gap is of any size it could be the source of drag and should be sealed for better aerodynamics.
I will add my own different custom visor sealed on the edges with variable vents in the center of the lens itself.
It might be worth considering sealing the standard visor around the edges with tape - the tape overlapping the gap need not stick to the helmet if it fits very closely so the flip up feature would still operate. Depending on how hot that makes your face you might want to make a couple of small holes in the visor adjacent to your forehead.
One way to make a nice clean hole in polycarbonate sheet plastic is to heat a piece of small diameter copper tube (as desired 1/4 inch diameter to 1/2 inch diameter) with a blowtorch and carefully push it through the plastic. Makes a nice clean hole you and can clean up the sharp edges with a Dremel or just a small piece of sandpaper.
I think the drag gains would be very small but every little bit counts.
Cheers,
Neal
+1 mph Faster
Cheers,
Neal
+1 mph Faster
