In Reply To:
Deal. If you look into the C13/C12 test.
But wasn't this the test the article mentions, that the lab did not follow the manufactures procedures on how to use the equipment? So how do you know how reliable the results are?
Quote:
The lab may have operated one crucial piece of testing equipment under conditions that violated its manufacturers' specifications, possibly because it did not have the operating manual. Furthermore, the software installed in the machine was 10 years old, based on an operating system no longer in use, and was designed for a different piece of equipment. Landis contends improper operation could produce erroneous readings.
The lab has insisted the instrument was in proper working order. The machine produced a carbon isotope ratio mass spectrometry reading purportedly showing the presence of artificial testosterone in Landis' urine sample, the key analytical evidence against the rider.
Just Triing
Triathlete since 9:56:39 AM EST Aug 20, 2006.
Be kind English is my 2nd language. My primary language is Dave it's a unique evolution of English.
