Hi,
I've a new Kickr which I can't get to work properly. I set it up Ok, did the spindown and it worked initially. It is on firmware 1.3.32. However, since then even though the app says connected, I am getting no power brake (so no resistance) and no power readings. Once it worked for 15 mins (power brake on and power readings, although 40w less than the Quarq was showing) and then the power brake stopped functioning and power reading had dissappeared from the Wahoo app..
I'm using Android (Samsung Galaxy s5)
Any tips on what a solution could be?
Regards,
David
Regards,
David
