Curious if people have had success with this thing with power matching in erg mode. I want to use my power tap hub as the source of Truth and have an external program like zwift call for x watts and the unit adjusts the magnet.
So far it has not been great. When I don’t have the power tap matched, it is very sluggish when I try to do something like 30 second intervals, it takes half the interval to get up to the prescribed wattage and then it won’t get me over 300. When I match with the power tap it shows a wattage of 40 when I’m standing still and seems to do a worse job of following the prescribed wattage. When I just switch over to using the presets in manual mode the transition from easy to hard is quite quick and ends up working out pretty well. I can almost live with that but it would be kind of slick to get the ergometer mode to actually work correctly. If I could return the thing I would but I guess I’m out of luck
I will continue to mess with it but I’m curious if others have had success
