As you know it's going to be very comfortable at Ironman Louisville 2014 no heat, Not! My question at what point/temp would one switch to a normal road helmet? I have a catlike aero and specialized Evade. As of Now the heat index is looking like 102. Are there study's at which heat affects body.?? I'm leaning towards the Evade
Re: IM Louisville helmet choices [andrewblerner]
I would go with the road helmet. (my 2 cents)
If you ain't first you're last. - Ricky Bobby.
Re: IM Louisville helmet choices [tfunk16]
I thought Jackmott had a study in another thread that showed no performance drop between the two. Though one may feel hotter it didn't significantly raise core body temp or results in reduced performance. However, I don't know what conditions they tested in. In cooler conditions your body may just shift cooling "capacity" to other parts of your body by diverting more blood flow there. Keep in mind that on the run you'll have dramatically less cooling despite moving at 1/4 the speed. I'd be surprised if it is an actual limiting factor at intensities well below max and well below FTP.
That being said, physiologically, you might want to wear the Evade even if it costs you 1-2 minutes.
TrainingBible Coaching
http://www.trainingbible.com
Re: IM Louisville helmet choices [motoguy128]
...you also might consider swimming a little slower for similar reasons, saving more for the bike & run.
andrewblerner wrote:
As you know it's going to be very comfortable at Ironman Louisville 2014 no heat, Not! My question at what point/temp would one switch to a normal road helmet? I have a catlike aero and specialized Evade. As of Now the heat index is looking like 102. Are there study's at which heat affects body.?? I'm leaning towards the Evadei did louisville in 2008 and 2013, 90 plus both days, wore aero helmet and didnt notice a bit of difference, stay with the aero
Going Aero (catlike) but thanks for all the advice, It's really appreciated
