robgray wrote:
pk1 wrote:
so you didn't do the things you usually do to deliver a good race performance and yet did just that anyway - what do you take from this? - is a focused build and taper just "marginal gains" at best
- is your race prep actually not as effective as you thought - anything you will change in future?
- were you just in incredible shape and could have have done incredible things with a proper prep
My theory is that it's the benefit of focus.
1. Not swimming only cost me 5 mins
2. I was in good bike shape (that's why I entered). As good as in any other race build.
3. Run prep was more race specific and with no long runs. But that only seemed to cost be about 15 minutes.
So my take away is: a) being in great bike shape makes a huge difference and b) if I continue my current run training just add some more volume I should be able to beat my run PR.
Maybe c) Texas is a fast course and we had great conditions so that's worth quite a bit.
Rob, I think you observations are in line with what I have seen for lots of experienced ahtletes.....20 min seems to be the delta between good/basic prep and optimal/finely tuned prep. To some degree, to maintain sanity in the rest of life, its a matter of where you want to "give away time". Lars' build is a great example....he ended up 20-30 min off what he could optimally do. In your case, you wanted to work your bike fitness, do the run on "maintenance mode" vs "no stones left unturned mode" and roll the dice that swimming is massive investment to get the marginal gains and that you can do a lot of swimming in the "taper period" and quickly get back a lot of the proficiency.
Interestingly, Lars skinned the cat the other way. With his ultra low hours he realized that he could really jack up his threshold with more swimming focus at high intensity that would carry over to his low volume intensity running. His running, I'd describe as minimalist, but in the same ranges as you for both of your performance. Maybe the takeaway is you can't turn off the run and get through the marathon but the swim and bike you can balance between the two (volume and intensity in each). Recall your 2014 IM South Africa on a low volume (for you) plan.
