Hi,
My name is Julie Donnelly and I'm a deep muscle therapist specializing in the self-treatment of sport injuries. The ITB originates at the lateral hip in a muscle called tensor fascia lata (TFL). The TFL goes along the side of your hip from the top of your lateral pelvis to the top of your femur (thigh bone). It then goes into the ITB (which is the tendon for the TFL) and goes down the side of your thigh and inserts into the lateral side of your knee.
All muscles pull on a tendon and then the tendon pulls on the joint. That is how a joint moves. Tendonitis is when a tendon is pulling so hard on the insertion point that it is causing an inflammation where the tendon attaches to the bone. But there isn't really anything wrong with the tendon, it's just being pulled too hard by the muscle. If you release the muscle you will take the pressure off the tendon and the insertion. It's like pulling your hair and hurting at the scalp. The analogy would be your hand pulling your hair is the muscle, the hair is the tendon, and your scalp is the joint. If you let go of your hair you scalp will stop hurting. Likewise, if you release the spasm in your muscle it will release the tension in the tendon and the joint/insertion point will stop hurting.
Back to the TFL and the ITB. As the TFL is going into spasm it is pulling up on the ITB, and causing pain at the lateral knee. To release the tension in your TFL, lie on the floor and place a tennis ball so you rest your TFL onto it (go gently, it will hurt). You need to lie on it for a minimum of 60 seconds. Move your hips around and hit all the painful points - they are all spasms. Then you need to release the spasms that have been created in the lateral quads when the ITB was being pulled tight.
To release your quads you just need to take an 18" dowel (like a clothes closet pole) and sit down at the end of a chair. Place the dowel all the way at the top of your thigh, where your leg meets your trunk. Then press down and slide (don't roll) the dowel down to just before your knee joint. You will find bumps that really hurt. They are the spasms, you need to press them out GENTLY. Do your entire quad - lateral, middle and inner.
This treatment has been proven by hundreds of athletes to be successful at stopping knee pain. It helps to put arnica gel on the areas that were especially painful to help heal the muscle bruising. If I can be of further help, feel free to contact me on my forum
www.julstro.com.
Wishing you well,
Julie
Don't let pain cause a DNF! YOU are your own Best Therapist! Visit
http://www.FlexibleAthlete.com and
http://www.Julstro.com to learn logical solutions to repetitive strain injuries and how to stretch safely.
