Ai_1 wrote:
lyrrad wrote:
You are testing FTP.
This is not anaerobic threshold. FTP is higher as you can only hold it for an hour.
Furthermore a 20min test only approximates your FTP from the 20min test by assuming you are like everybody else and can hold a certain percentage above FTP for 20min.
You are not everybody.
Some people have very little extra over threshold.
Some people have a vast amount.
Depending on you, your FTP estimate may or may not be accurate.
The only thing you know for sure is your 20min power.
If you were measuring actual threshold, then results are usually much more consistent.
But you are not, so what you are really measuring is your state of rest.
Plenty of rest, and your 20min power goes up, not enough rest and it goes down.
Heat effects will show more at FTP type powers as well.
This is the danger of using 20min tests to estimate FTP.
If you had of run a full HR vs power vs lactate, it may very well have shown that your actual threshold had not changed at all, but that your power above threshold was better in the second test due to whatever factors.
Thanks for your feedback.
Yep, it's true to say a 20min test to estimate a variable that's specified in terms of a 1hr period is a bit odd. As far as I'm aware, however, it's somewhat the norm. In fact, unless I missed something, Zwift doesn't provide a 1hr FTP workout (not that you couldn't do it yourself but you wouldn't have the same automated average power and updated in-game FTP figure).
It would make more sense to base training intensities on 20min power instead of applying a 95% correction first and calling it FTP, but the result is essentially the same.
I'm not about to do regular all out 1hr efforts in order to get more accurate FTP figures. The test hurts too much and would interfere too much with other training the week I did it. I can hurt myself just fine, as I see fit, in races. The motivation would be hard to conjure up for consistent all out 1hr FTP tests and this would possibly make the results less consistent. Not something I plan to start doing any time soon, and probably never.
Incidentally, my average HR was very similar on both tests. I don't have the figures to hand but I think the first was about 167bpm or 168bpm and the second was 169bpm. I would also think I was similarly rested for both having done moderately hard bike sessions 2 days earlier and no training the day before in both cases. Both were done at a similar time of day but I can't say whether my amount or quality of sleep in the previous days was similar. That's a level of detail that isn't likely to be sustainably kept equivalent by amateur athletes with somewhat "normal" lives. If that makes the tests pointless, so be it.
20 min testing was developed for one reason only.
Convenience.
As were all the other whacked out tests developed before it.
A full test is not easy for a home based or basic coach to do.
You need to be experienced to control variables and be skilled in interpreting what you see.
Also not many people had access to lactate meters or even HR monitors when all this started.
In a well trained, well rested athlete that is in the middle of the bell curve, the 20min test works well.
It is also easy for untrained people to administer.
The results however do not fall well for edge of the bell curve athletes or anything but well rested and well trained.
In some respects it is just a slightly better version of things than the garbage HR estimating formulas based on witchcraft and magic.
Doing a full HR step with or without lactate vs power is the only proper way to know what is really going on.
When you look at a full test, you will see in a well rested and reasonably trained athlete, that the graph is basically a linear progression up to the Aerobic threashold where you will see a small flatening as you start to see the presence of increased lactate from basal, and then the graph continues in a linear fashion once more up until the anaerobic threashold where it flattens once more.
These two areas of linear increase will be parallel in a well rested test. (testing using power or running speed, as these progress linearly)
So you will see a line, a small flattening, then another line to a flattening with the two lines parallel to each other..
Several things can happen that will change this general graph.
A preponderance of long distance aerobic training without any higher intensity stuff will flatten the first line compared to the second one.
So will not being rested, a little sick or overtrained by compressing the second section.
But if you have a good solid graph to base further testing on, you can see if it is an extension of the low output aerobic zone that is causing the flattening or a steepening of the higher output sections that create the disturbance from parallel.
A concentration of high output training will do the opposite, compress the first line and flatten the second line.
So will a simple lack of base training.
Being overtrained will also flatten the second line as it is harder to push into those harder heart rates and it may at first look like you are making good gains in the upper end with the flatter HR, but in fact, you have gone too far and need to back off.
Again comparing to a known good previous graph will help interpret the graph.
There is heaps more, but basically there is a flattening of either the first line or the second.
And you need to understand why. Understanding the phase of training the athlete is in as well as general health and state of rest is needed.
But the graph will tell you everything you need to know.
Not something that everybody has the knowhow to do or interpret but less work than trying to slam out an hour TT and it still gives you a shitload of data that all the other estimates don't even hint at.
So really, a 20min test tells you how good you can do a 20 min test.
That's pretty much it apart from some amateur sleuthing in regards state of health and rest.
So don't read too much into each individual test.
What the test is good for is if it is showing a trend over time.
Are you getting higher power each time in a nice progression?
There is too much variability in the result for individual tests to be taken too importantly as the test cannot tease out the reasons for the differing results.
You can over time, figure out what's going on with the help of other info, but really a single test tells you not much.
This is one of the reasons HR training gets a bit of a bad wrap, it's not being used properly.
You must have proper full testing for it to be relevant and a home based amateur and most entry level coaches just can't or couldn't be bothered to do it.
