I've paired the OH1+ with the FORM goggles and get an accurate heart rate reading, however, after the first flip turn, I lose connectivity ("disconnected"). During rest interval, connectivity comes back. I wear a cap and have the sensor snug against my temple. Does anyone else have this issue and are there any hacks out there that will help maintain connection after flip turns? Thanks!
Re: FORM Goggles & Polar OH1+ [F16kidd]
BTLE has a range of 1-2in under water. Make sure (if you haven't already) that the OH1 is on the same side as the Form's electronics, and try clipping it upside down in case the BTLE chip is on the far side from the goggle (depends which eye you use for the HUD).
ECMGN Therapy Silicon Valley:
Re: FORM Goggles & Polar OH1+ [Titanflexr]
Awesome. Thanks for the advice. Sounds like this might be an option after doing some research regarding BT underwater.
The FORM v2 goggles which are currently in Beta testing have an optical heart rate sensor built into the goggles with no need to add a 3rd party sensor.
