rruff wrote:
Thanks for the info. I would have guessed a little less benefit, but it depends on how her power scales with altitude.
Hence the variability quoted.
http://alex-cycle.blogspot.com.au/...record-part-iii.html
e.g. Molly Shaffer Van Houweling in an hour ride at Carson rode 44.173km
and in 3 subsequent hour rides at Aguascalientes averaged 45.999km (45.637km, 46.088km, 46.273km) a difference of 1.826km to the average distance at sea level
(1.464km, 1.915km, 2.100km respectively).
Considering that at each attempt Molly likely improved her technical execution as well as some aero refinements and possibly form as well, then seeing the gap at the higher end of my estimated benefit range does not surprise me.
rruff wrote:
I'm curious about how different tracks vary in speed due to material, smoothness, banking, etc. The fastest tracks are usually wood, and of course these are indoors. I don't know if concrete is inherently slower, or if it's just that wood is cheaper to use if it's going to be enclosed anyway. Any ideas? Do you have experience with both?
Most concrete tracks are not super smooth, and certainly don't roll as nicely as good wood tracks (the exception in my experience are tracks that are made of large sheets of timber rather than the thin timber strips used in most modern tracks). I'm not sure why this is the case but quality timber surface is definitely faster to roll on. Perhaps there is some inherent "give" in timber that helps.
As to other factors to consider, it's often easier to maintain a good line on a larger track such as COS 333.33m and that can be an advantage. The slight downside is the centre of mass travels further per track km on larger tracks than on smaller ones.
http://www.cyclecoach.com http://www.aerocoach.com.au
