I'm riding on carbon wheels for the first time. I got them around christmas, and had only done a couple rides outdoors until recently. I've noticed a lot of rubbing when I climb, and nothing when on flats and descents. I have a 2012 P2, and weigh around 200 pounds. The only thing i can think of is with my weight, that the steeper the climb, the more force I'm putting on that rear wheel causing it to flex, more so than the stock wheel would.
Initially I Thought it was rubbing against the frame(it did this when I first bought it, and i pushed the wheel back). then this weekend it was still doing it despite having moved it almost as far back as i could. I just flipped the switch to open the pads up as far as possible and all the rubbing stopped. I assume this is the issue, that I just need to set the brake pads farther apart than I did before. Is this normal? And the wheels are an a chinese knock off, so I don't know the specific brand, or if there is one.
