over9000! wrote:
I don't know if my sinus has some sort of inborn deformity, but I am experiencing difficulty breathing through my left nostril. The right nostril is fine.
Does anyone have any cure for this problem? Oxygen intake is critical to aerobic performance.
I've tried netti pot and water definitely flows easier from the right nostril to the left than the reverse.
Most people have some difference in left right nostril balance. It is normal to favour one nostril or the other but generally most people's nostrils take it in turns to be more dominant to airflow. Dominance is also affected by fatigue.
I have yet to finds a link between left leg right leg power dominance and left right nostril dominance due to a lack of subjects prepared to have one nostril blocked.
Generally left right nostril dominance can be corrected by getting a Pikey to punch you on the side of the mush which is less open to airflow.
A less painful method is to change the side you most predominantly sleep on.
Better still is take up snorting cocaine, in time it will even out the airflow.
Snort warm salted water, tends to shift all sorts of crap out of blocked sinuses.
