One of your older admirers on ST. Man you have spunk.
A shorter crank length has it's benefits. I wish there was this discussion while I was racing in my teens-twenties.
A shorter crank length has more clearance in cornering. Too many of my racing buddies were short on small frames with short cranks. They could pedal through corners that I couldn't without touching a pedal. They also seemed to be able to start pedaling sooner while coming out of the corner. Going by when they were pedaling in corners or curves was no guarantee that I wasn't going to hard touch a pedal and go down.
A shorter crank creates more clearance between our feet and the front tire. Not as serious as cornering; yet it can make a difference while starting and stopping with a turn. Keeps my cycling shoe toes cleaner with fewer touches.
A shorter crank creates a shorter distance to travel. As we get older leg speed does get to be an issue. I seem to be able to react faster in my 170s than the others in their 175s while riding in a group. This helps as I am not the strongest one in the group and can't afford to miss a wheel.
A shorter crank does allow for more "gut" room. As the pedal's circle is not as big, the pedal is not traveling up as high (unless your seat is too low). This helps save the hip flexors.
Now would I jump down to 165s from my 170s? Not unless I needed to. Believe in progression and adaptation. If I started using the lowest easily available cranks it would be hard to go smaller if I needed to do so.
Other things are also impacted by smaller cranks. The chain rings just got bigger by shortening the cranks. My 50 up front with a 170 is close to a 52 with a 175. So if I was on a 52 chain ring, just changing the crank would make it a 53/54 which would be harder to turnover or I would be spending money to go to a 50. The nice thing about a 170 crank and 50 chain ring is that it matches up well with the others on their 175 cranks and 52s. Plus I have more cornering clearance, gut room and less pedal distance to cover while reacting to their darn surges.
Keep up the good work Dave. You give us somethings to talk about.
Indoor Triathlete - I thought I was right, until I realized I was wrong.
