Hi all,
My LBS is currently working on adding the cateye remote option so that I can both keep my Magura RT6 brakes but also have gear shift buttons on the brake levers (have soldered the cateyes into the box out of another set of TT shifters). This is quite a common custom piece of work on the Cervelo P5s with the Magura RT8 brakes - but is made easier on the P5 as the aerobar is the integrated 3T Aduro.
However the P3 only comes with the 3T Aura which according to the LBS (and I have no reason to doubt them) doesn't have the ability to internally house both the hydraulic brake cables and the extra Di2 cables. I don't want to run the Di2 cables externally as it will not look that great. Also I cannot upgrade to the 3T Aduro as (according to the 3T sales rep and the LBS) it is not compatible with the P3, only the P5 (notwithstanding the extra cost!).
I could drill extra holes into the Aura, but drilling into carbon is highly NOT recommended.
The option the LBS has given me is to swap to the Zipp Vuka Alumina bar as it is alloy so extra holes can be drilled. However I'm not sold on the look of the cow-horn curved corners of this particular bar, and it seems like a compromise compared to the 3T Aura carbon option.
Putting aside the obvious cost increase, would upgrading to the Zipp Vuka Stealth work so far as internally housing both cables on either side?? - I see from the reviews that the Stealth has two exit points on either side, but I'm not sure if they are wide enough to cater for the cabling.
Would like to have a carbon base bar if possible, but I guess I will have to go alloy if there is no other way. Any suggestions would be appreciated!! Thanks
