lyrrad wrote:
Tom A. wrote:
BryanD wrote:
https://www.bikerumor.com/2017/05/09/breaking-campagnolo-goes-road-disc-brakes-levels-eps-mechanical/
Since the internals are Magura designed, I wonder if (hope!) they "work" with the Magura RT brakes... The artical says that they are Campy through and through...... You need better sources ;-)
"Developed in conjunction with — and, in part, manufactured by — German company
Magura..."
"...Campagnolo takes a page from
Magura’s latest mountain bike levers, using a two-position toggle that physically changes the mechanical advantage between the brake lever blade and piston shaft."
"Not surprisingly given the association with
Magura, Campagnolo hydraulic brakes use mineral oil..."
https://cyclingtips.com/...isc-brake-groupsets/
