jkhayc wrote:
Titanflexr wrote:
+1 on getting a GP5000 instead of the Gatorskin, and using a latex tube.
For the valve issue,
you may want to widen the hole the valve goes through. This allows you to angle the valve slightly to get the head on. You can always use the valve stem nut to stabilize it after inflation (though I find it unnecessary).
i think this is a very bad idea, especially if you use a latex tube.
We’re talking about increasing the hole diameter by <1mm; the reinforced area is still way larger. Just make sure there are no burrs. I’ve been running a disc with latex and no rim strip for over 15yrs. w/o issue.
You could use a little square of butyl tube with a hole for the stem to reinforce the area, but unnecessary imo.
ECMGN Therapy Silicon Valley: Depression, Neurocognitive problems, Dementias (Testing and Evaluation), Trauma and PTSD, Traumatic Brain Injury (TBI)
