The BB386 seems to be wider than the BB86. It shouldn't be. If anything, the GXP spindle is slightly long for a 386 and requires a couple mm of spacers. When I installed the GXP crank. It was butted up against the frame on the drive side. The spindle came out the other side of the BB. But only the grooved part that the crank arm attaches too. The smooth main body of the spindle didn't reach the other side of the BB and the crank would wiggle in place and you could see the spindle wasn't fitting tightly around the BB where it exited. Which made me look at my old frame and realize it was BB86 not BB386 The confusing part is that BB86 and BB386 have the same bearing position (width).
I also have a Red BB30 crankset I could use. A true BB30 crankset is too narrow. If it's a RED with the integrated (non removable spider) it is surely too narrow. SRAM makes things confusing by calling all of their 30mm spindle cranksets "BB30." It's a Red 22. It's 5-6 years old. The spider is removable. When I held it up alongside the GXP crank, the spindles appeared to be the same length. I might be wrong, didn't have a chance to measure them before I ran out for work. On the BB30 spindle is says PF30 BB30 if that makes any difference. Cool. Consider that crankset a BB386 crankset instead.
I noticed Stages has longer BB30 spindles I could get for the Red. It won't work assuming you have the integrated spider.
Spider is removable so I'm assuming I can order a new spindle? I think the current RED crank will fit.
If I swapped out the bottom bracket, can I install a bottom bracket in the BB386 frame that would accept BB30. No. A BB386 frame is about 22mm wider than a BB30 frame. I'm assuming this point is moot if I can change the spindle.
What bearings are currently in your BB386 frame? Any chances there's 30mm bearings in there with a reducer/spacer installed? What frame is it? I'll have to look again but from what I remember is said FSA Megaexo 24mm. They kind of look like this but not exactly sure.
https://shop.fullspeedahead.com/...indle-to-bb386-frame
If it is these, I'm assuming they can be removed? Would I then be left with a 30mm opening?
The frame is a Blue Triad Elite. Bought it without a groupset. Was putting my Di2 on it. I thought my old frame/crank was BB386 so didn't ask about the bottom bracket on the new bike. Hot dang Mattr, I think we're getting close.
Is your RED crank a power meter crank like a Quarq spider based PM? (It doesn't matter for sizing, I'm just curious as it may explain a couple things.)
You jumped ahead of me with that FSA link. Nice work. The only BB386 frame I have owned came with 30mm ID bearings installed and the reducer spacer things you linked (which also widened things by about 5 mm). Those suckers pop right out. I'm pretty sure if you are installing GXP, you want
these ones instead.
If those reducer things pop out, your RED crank should slip right in with no modifications or spacer needed. Make sure the dust caps didn't fall off the bearing when pulling those reducers out then put your RED crank on as normal. I think I removed the reducers with a long hex bolt since none of my BB specific tools fit right. Basically I placed the big hex head against the inside of the reducer (from the other side of the BB) and lightly tapped it starting at 12 o'clock, 1 o'clock and so on until it popped out, then repeated the process from the other side.
Think of it like this picture, but tapping around the edge of the reducer. It's been a year, so I don't remember why I didn't actually use the tool in the picture. There must have been some sort of fit issue.
I'm pretty curious now, so let us know how it goes.
