motoguy128 wrote:
Tom A. wrote:
umcade wrote:
Tom A. wrote:
danimel59 wrote:
Hi all, does anyone have experience on the 3rd brake (rear) lever that mounts below your shifter.
Good or bad? how difficult to install? Thanks
Actually, I find an auxiliary rear brake lever to be VERY useful. Just understand the intent of it is to scrub speed without having to get out of the extensions, NOT for heavy braking needed to come to a stop or avoid obstacles.
If you need to scrub speed, then I presume you are going too fast, so why are you in aero? Sit up and get some wind braking and have your hands where you can effectively brake.
Mostly for taking corners at the proper entry speed. Being able to stay in the aerobars, and being comfortable with that, is faster.
If you really pushing the handling limits of the bike that you can't pedal anyway due to ground clearance, so sit up and relax for a moment.
I'm curious what races you do where road smoothness and visibility are so good that you can corner hard enough in aero to "Need" to scrub off speed? Every I've done, the faster corners have questionable sight lines and road surfaces (pavement cracks, seams, transitions). There are quite a few where I will stay aero. It's not like it's a criterium where you know the cornes have been swept and you get a few warm-up/sighting laps.
Here's an example from before utilizing a 3rd brake, where it was corners like this that made me wish for a bit more "security". This turn is taken at the bottom of a small hill:
In the end, what it comes down to is that I've tried it both ways, and I prefer what the 3rd lever offers, fully understanding it's not intended for heavy braking.
Of course, since I use CX bar top levers inside the "loops" of my 100K bar anyway, adding a 3rd lever is pretty easy ;-)
